Electricians revenge
0 members (), 161 guests, and 10 robots.
#153721 04/27/04 07:48 PM
so if you can get next to a stud, is it acceptable to screw a box to the stud with sheetrock screws? or do you have to make a big enough hole to secure a bracket type of box?
#153722 04/27/04 08:09 PM
Richard, if you can secure the box to the stud you have it made. There is no specific criteria I know of beyond
The metallic outlet or switch boxes shall be securely fastened to the studs
Good luck
Roger
#153723 04/27/04 09:01 PM
Richard: 314.23(B)(1).
Ryan Jackson,
Salt Lake City
#153724 04/27/04 09:38 PM
Oops!!! [Linked Image]
Roger
#153725 04/29/04 07:20 PM
thanks guys, i just want to do the right job, and not "this is the way it has always been done". new work construction is a lot easier, in that you can build your support if the stud isn't where the customer wants his device. but with old work, it is sometimes hard to convince him(or her) that they will have to get someone to spackle and paint for that one outlet in the dining room, and the paint is hard to match, etc....
