181
Goofy Dude! Now What Man!!
Is the hole in the wall an escape route?
Joe, seeing that the switch is in the off position, do you think it was a test? Roger
I bet it won't turn ON. Most worker drones don't care if it won't turn off. They just care that their machine won't run. It should have a lockoout and red tag but it may not be quite as dangerous as it first looks. Or, at least, that's what I hope!
Roger:
I don't really know because the picture was sent to me by a student. Could be though, the mechanism may be hung up or damaged.
The switch is "OFF" but odds are that it is still made at the top? I wouldn't be surprised if someone also used those solid "pipe" non-fuses or jumpers.
I'm confused.
The handle looks up to me, meaning on. The note says 'main' switch, not isolation or disconnect. I have had to deal with local switches that fail to change contact position. What I usually do is drill, tap, and bolt the handle in the 'stuck position'. I then put a big red tag on it that says: "DANGEROUS - GO AWAY"
Then I order the parts to fix it; or if they are on hand, I make sure the supervisor has them changed as soon as the equipment allows a shut down.
Pinemartin, the protrusion on the switch you're looking at is a rocker type mechanism. If the same protrusion was at the bottom the switch, it would be in the closed position.
I think this may be a GE or Siemens switch but don't hold my feet to the fire on this.
Roger
You are right. I recognize it now. I thought it was a grasping type handle as opposed to a push rocker type.
Pinemarten, I then put a big red tag on it that says: "DANGEROUS - GO AWAY" Now that's what I call a lock-out tag!.
The scariest part is I think I recognize this guy's writing. Hmmm, Hmmm.
