1 members (Scott35), 161 guests, and 30 robots.
#153507 01/19/04 06:10 PM
That is correct. A T stat is a temperature sensing device that needs to be mounted at a height that will reflect the average temperature of the room which is usually 60".
#153508 01/19/04 06:23 PM
ADA requirements may keep it to 54" if it can be side reached, or if forward reach is the only way to approach with wheel chair 48" max.
The fact that 60" is a good height for temp sensing makes no difference to the ADA requirements.
Trane makes a nice remote sensor for use in this kind of situation.
A conventional looking thermostat that can be placed anywhere you want and install the remote sensor where it will work the best.
#153509 01/19/04 07:30 PM
A little off the subject, I have heard from A/C people that they actually install dummy T stats in some office spaces so people will think they are controlling their immediate areas.
They claim this placebo really works. [Linked Image]
Roger
#153510 01/19/04 07:56 PM
Roger I believe the Placebo works. [Linked Image]
Around here Johnson Controls handles most of the buildings we do.
The popular thermostat that is used has a slide control with no numbers just blue to red colors like the control on a car heater.
99% of the time all the way from "cold" to "hot" only results in 1 or 2 degrees of change.
The other 1% are in the VIP offices and the control will be programed with a larger temperature differential. [Linked Image]
#153511 01/20/04 04:11 AM
Ryan_J: there are allowances in ADA for job requirements. When I started in my building as an equipment Mechanic, one of the "legitmate" requirements was the ability to work in confined spaces and from ladders and lifts. A significant degree of physical dexterity is really necessary. Most of the jobs in the production side have physical requirements - wheelchairs don't work and the plant can not practically be modified. We do, however, have a large contigent of hearing impaired. It is feasable to modify alarms and warnings to accomodate their handicap. On the other hand, my brother-in-law was a network administrator. For the last years of his life, he was in a wheelchair and the only thing he could move was his head. Technology could accomodate him in his job. Although it is pretty rigid, ADA can't be 100 % every time
#153512 01/23/04 05:31 AM
Roger,Bob,
We've installed a lot of these fake t/stats in places where we have Commercial Air Con equipment and I must agree with you Bob, it really does work!. [Linked Image]
Most of the time, these are installed because we are sick and tired of going to reset the roof-mounted units that have gone out on O/Load because the things have been cranked up to a Million degrees (or minus a Million) and all the windows are open too!.
Oh and by the way, we tell them to keep the darned windows shut, too!. [Linked Image]
