by gfretwell - 05/14/24 12:28 PM
Electricians revenge
1 members (Scott35), 197 guests, and 14 robots.
#15313 10/14/02 04:23 PM
Change the switch, trace the line back to the next junction and look for brittle, frayed wiring, loose nuts, etc.
#15314 10/14/02 05:59 PM
Screw-base compact-fluorescent lamps are available in up to a "200-watt" incandescent equivalent for about $15...having only a 45-watt electrical demand.
Little old grandmas with failing eyesight seem to love extra-bright light in their kitchens; hence many a big lamp in carbonized ceiling fixtures.
[This message has been edited by Bjarney (edited 10-14-2002).]
#15315 10/14/02 08:59 PM
Schven has it right, they are available in our local hardware store for almost nothing. I will let you know how it works.
Trainwire
#15316 10/14/02 09:41 PM
Did anyone mention "How close the house is to the utility transformer?" Here in my house, the transformer is right outside my house. The voltage I have coming into the house is approx. 125-127 volts. My bulbs use to pop all the time. I need to buy the 130 volt bulbs. If the house is farther away from the Utility trans, I have seen voltages as low as 120 to 106 volts.
