0 members (), 166 guests, and 8 robots.
Page 7 of 7 1 2 3 4 5 6 7
#153045 08/19/02 11:30 AM
Home Depot sells cloth friction tape!!!
Is it a good idea to wrap modern day splices (with wire nuts of course) with the vinyl tape and the friction tape over it?
Or is that overkill?
P.S. I have a couple of those Leviton s.m. outlets. Also the Eagle versions. They're still manufactured...my aunt's apartment has a bunch. Her place needs an entire rewiring, but I'm not going to touch it...it's a job for a real electrician...there are wires crumbling inside the walls.
#153046 08/19/02 03:08 PM
regarding sparky's tandem/parallel outlet:
At one time, there were two styles of 110-volt/two-pin plugs. One was the regular parallel blade plug and another called "tandem." The outlet was designed so you could use either type.
Later outlets would use T-shaped holes for the same purpose.
Look at the following pictures in this website and you'll see pictures of the outlets and the tandem plug that would have fit it:
http://home.netcom.com/~wa2ise/power/power.htm
sven
#153047 01/20/05 12:20 PM
That "weatherhead", "monkey's fist" or "birdseye" is known as an "A-Head" in old catalogs. Creighton
#153048 03/10/05 02:34 PM
Thanks Creighton!
#153049 07/09/05 05:40 PM
Looking for more old electrical equipment, if you have some send me the pictures so I can load it up here.
#153050 07/10/05 11:20 AM
"Monkey Fist"? "Bird's Eye"? NO. These are called "A-head"s.
Creighton
#153051 07/19/05 02:42 AM
that outlet in the pic above the PB switch, looks like it's installed in the floor, judging from what appears to be years of dirt and other debris in the slots.
Cliff
#153052 07/21/05 01:22 AM
Earlier in this thread, there was a couple of mentions of Trumbell Electric.I believe they made quite a variety of electrical equipment. I suspect a number of you carry keys to locked electrical cabinets. One of them may be labeled TEU which actually originally stood for "Trumbell Electrical Unit"
