0 members (), 1,128 guests, and 28 robots.
Bjarney, It's a 6-20, right?...S
electure, I’m missing your question. The two-blade devices I referred to are 2-20.
The three-bladed device are NEMA 10-20 and up. These are officially {by the NEMA WD6-1997 standard} "non-grounding" devices.
Sven’s second-to-the-last picture looks like a NEMA 6-20 and the last looks like a 6-15. These are officially "grounding" devices.
Bjarney,
My "boobit".
I didn't see that the diagram didn't include the u-ground...S
el—
I hear they’re planning for 110% all-plastic air conditioners and heaters..
—Bjarn
I have one of those, pulled it from a soon-to-be-demolished house back in Lehigh Acres, FL. was found installed with 14/2 romex.
Cliff
I haven't seen one of those three-place receptacles for almost two years, now! BTW, triple switches were also made.
The wider, or 'polarised' blade was first introduced in the '30's, I believe, but other affairs kep it from becoming universal until the early '50's. Even then, many appliances had their shells grounded to the neutral...something that didn't end until the early '60's, with the general acceptance of three-prong receptacles.
What did the code say about non-NEMA patterns? Nothing- there were no NEMA standard patterns until the early '70's, I believe. Up to then, it was common for plugs to have two widely different ratings, and be used on teo completely different systems.
Non-NEMA patterns are still in use. The RV industry uses a non-NEMA pattern for the power pedestals found in RV parks. The 3-prong range and stove receptacles are likewise non-NEMA plugs. And- surprising no one here- California has seen fir to design their own.
I saw triple toggle switches at Home Depot...as recently as....two days ago.
Expensive buggers they are too! [Linked Image]
Looks like the Japanese are still making those triplex sockets.
[Linked Image from meiko-g.co.jp]
So is Leviton:
[Linked Image from levitonhelpdesk.com]
[This message has been edited by Larry Fine (edited 05-27-2005).]
Larry Fine
Fine Electric Co.
fineelectricco.com
Any idea on when that Ivory Bryant I- style receptacle was manufactured? Is it only supposed to be used on 120 VDC applications? As far as the 20 amp/240 volts....considering that's the same pattern used nowadays except with a built in ground....usually for window air conditioners and the like....
Trumpy 5
davey 1
551,522 Are you busy
426,039 Re: Forum
396,823 Need opinion
