0 members (), 2,633 guests, and 11 robots.
#15024 10/06/02 07:46 PM
Anyone know of any electrical formula web sites?
#15025 10/06/02 07:52 PM
Hyper-Physic's is fairly extensive. are you seeking anythin specific?
#15026 10/06/02 08:11 PM
Exactly what I was looking for.
Thanks sparky.
#15027 10/07/02 02:19 PM
You could also try this site:
http://bizprolink.netbusiness.com/cgi-bin/bvsm/nb/nbcalc.jsp?OID=33572
Looks like it does all the standard calculations along with offset bends.
#15028 10/07/02 03:00 PM
Browsing around Hyper-Physics:
"What happens to electric charge in household circuits"
"In the process, as the charge progresses through the appliance, its voltage drops from 120 volts to essentially zero volts with respect to the earth. This spent charge is then dumped to the earth through the ground wire. In the standard US receptacle, the charge at about zero volts is carried back to the electrical panel through the neutral wire and then transported to the earth by the ground wire attached to the electrical panel."
This should be corrected to indicate return to source.
[This message has been edited by Thom (edited 10-07-2002).]
#15029 10/07/02 06:14 PM
You may want to go to a local bookstore and get a Pocket Ref by Thomas J. Glover
I can't begin to count the times I go to this little black book for formulas and reference tables.
ISBN: 1885071337 | Sequoia Publishing, Incorporated | 2002-04-01
#15030 10/07/02 09:58 PM
I have that pocket ref, it is great alot of stuff in there you can get it about anywhere for about $12 or less.
#15031 10/09/02 06:52 PM
We have some formulas and Calculation examples here at ECN.
Try the Technical Reference area and the Electrical Theory area.
If you have some suggestions for formulas to add, let me know.
Scott S.E.T.
