Would just like to relate a local situation that occured here yesterday.
A guy that works alone normally, took on an Apprentice on Tuesday and they went to do a job in a house just down from the road from where I live.
Apparently, from what I am told, the Electrician opened the Switch-board up and the Main Phase wire fell out of the Main Switch, the bare end of which landed on the neck/shoulder of the Electrician, he was standing on a set of Aluminium steps that had no rubber feet and it was in direct contact with the concrete floor below, suffice to say, the Electrician could'nt move.
Had his Apprentice not known what was going on, he would be deceased now.
He then ripped the Pillar Box open with a Sledgehammer and killed the supply to the house and then proceeded to administer CPR.
I was responded there, because the Apprentice pulled all 3 Mains fuses in the box and cut power to 2 other houses.
Don't bag the guy for this, though, given the same situation, I'd do the same, Apprentice or not!.
The Electrician is still in hospital, but he is alive, thanks to his new employee.
I had a word to the young fella after the Ambulance left, he apologised profusely for breaking the Pillar box cover, I said that we had about a Million more in the Power Board store!, and not to worry too much about it.
I also gave him a big pat on the back for his actions and told him that all Electrical work is not like this and to encounter this in your first week, is really unusual.
He said he would stick at it, I said good on you mate.
I added that his Boss should get some better ladders, he agreed!.
BTW, the Complaint has been lodged with the EWRB, as to the loose Mains, this guy is renowned for this sort of thing and I want him struck off the Register, It's not right if you can't Torque screws properly!.
{Message edited to add last part
[This message has been edited by Trumpy (edited 10-31-2003).]
