WASHINGTON, D.C. - In cooperation with the U.S. Consumer Product Safety Commission (CPSC), Excel Industries Inc., of Hesston, Kan., is voluntarily recalling about 1,500 Hustler "FasTrak" riding lawn mowers. Excessive heat, vibrations and wear causes the fuel line to droop over time and rub against the transmission fan, causing the fuel line to be cut. This poses a fire hazard and a risk of burn injuries to consumers.
Excel has received two reports of incidents where gasoline leaks were discovered. No injuries or property damage have been reported.
Click >> more info
