33
Posts: 3,669 Likes: 4
Administrator Member
WASHINGTON, D.C. - In cooperation with the U.S. Consumer Product Safety Commission, (CPSC), Eugenio Serafin Inc., of Bayamon, Puerto Rico, is voluntarily recalling about 32,500 electric showerhead hot water heaters. The showerhead hot water heaters are attached to the shower's water supply piping and connected to the household electrical supply source when central hot water is not available. The nozzle can be easily unscrewed, exposing the uninsulated heater coil. The heater coil's grounding screw does not sufficiently reduce the current through the water, posing an electrocution and shock hazard to the bather.
CPSC and Eugenio Serafin have not received any reports of injuries or incidents associated with these showerhead water heaters. This recall is being conducted to prevent the possibility of injury. Click >> more info
