Perhaps some of you may be interested in these pictures of pole mounted transformers.
We're always interested in stuff like that around here!
![[Linked Image]](https://www.electrical-contractor.net/ubb/smile.gif)
Welcome to the forum Martin.
Wolfgang,
That means that you have 1 phase distribution on the Isles?
Yes, to a limited degree. As soon as you get anywhere with a concentration of houses in a village or town you'll find 3-phase transformers with a 4-wire 240/415V distribution network around the settlement (each house tapped for 240V single-phase service).
In more rural areas though, you'll often see single-phase spur lines tapped from the 3-ph 11kV network running for relatively short distance to serve isolated houses. The two single-phase xfmrs in my post above are such examples, each one serving just a couple of houses which stand on their own in the countryside.
This being a mostly rural area, we also have little hamlets which have maybe a dozen or two homes spread out along a lane over a distance of maybe a half mile in what is otherwise a fairly isolated area. Some of these have a single-phase (2-wire) 11kV spur line and a single-phase xfmr which feeds 3-wire 240/480V distribution lines which run through the settlement, again with the houses just tapped for 240V 2-wire service.
Here's an example of the latter (notice the three LV wires and two fuses):
The single-phase HV spur in this example continues a short distance to a xfmr serving another tiny isolated community.
[This message has been edited by pauluk (edited 01-12-2006).]
