Electricians revenge
1 members (Scott35), 162 guests, and 11 robots.
#14361 09/21/02 07:56 AM
F
you can use the closer of the two or both.If you drive a new rod it will still have to be bonded back to the building grounding electrode system
#14362 09/21/02 08:58 AM
F
I've been looking through several of my 2002 NEC Handbooks. So far I have not found an exception for a separtely derived system. It seems as if whenever a metal water pipe is the grounding electrode for a building a supplemental ground must be used.
[This message has been edited by Frank Cinker (edited 09-21-2002).]
