1 members (Scott35), 413 guests, and 35 robots.
#141690 10/08/04 03:20 AM
3
"nema 1-20P ?" I had a look at a NEMA configuration chart for a 120V 20A connector & I could find a 5-20P but no such animal as a 1-20P exists...what connector would one use for a double insulated appliance that drew > 1875 watts?
http://www.hubbell-canada.com/wiring/bryant/pdf/b/b5.pdf
[This message has been edited by 32VAC (edited 10-08-2004).]
#141691 10/08/04 10:27 PM
IMO use a 5-20, even for the sake of using the ground pin for polarity.
#141692 10/09/04 02:03 PM
Strangely, there is a NEMA-standard DC wiring-device series… NEMA “FSL-1” rated 28VDC 30A.
[Linked Image from 6l6.net]
See page 15 of www.hubbell-wiring.com/library/brochures/msection3.pdf
#141693 10/09/04 03:02 PM
You're getting rather close to British ideas there, where a BS1363 plug has the ground pin whether it's needed or not. Some of the latest molded-on plug sets actually have a plastic earth pin.
