1 members (Scott35), 191 guests, and 10 robots.
#141531 10/04/04 08:49 AM
Likely, or it isn't grounded at all. Both versions are possible.
#141532 10/04/04 11:54 AM
C-H Offline
If they hadn't tied the neutral to the protective earth, the would have been no reason to install the Schuko in the first place [Linked Image] Simply use a neon pen to test which wire is which. Probably safer than relying on colour coding.
#141533 10/04/04 02:02 PM
Sure. Plain showoff. I've seen many many Schuko receptacles without any ground. Technically of course it doesn'T make any sense at all, but many electricians don't seem to care.
