Dave,
The routine on the new switches here for a phone off-hook but nothing dialed is weird:
Dial tone for about 20 sec.
SIT (three ascending tones)
Announcement repeated: "Please hang up and try again" for about 20 sec.
Quiet line for approx. 3 mins.
Howler for approx. 3 mins. (it fades in at the start over a period of about 10 secs.)
What then? Permanent signal or quiet line? Nope -- You get dumped back to dial tone!
After this one times out again, you go to SIT and 20 secs. of the announcement once more,
then a dump to permanent quiet line until you hang up.
Quiet line here still has battery, and from the background noise it sounds as though at this point you're on very unbalanced power.
I'd left BT before these switches came into use, so I have no idea why it's arranged this way. Very strange.
Depending upon type and configuration, older switches would either let you listen to dial tone all day, or time out after 30 to 60 secs. In most cases after timeout you would get either N.U. tone or equipment engaged tone, followed by a quiet line.
Howler application wasn't automatic as it is now. It would be applied to the line manually if a number was reported as always busy and verification showed the line just off-hook.
Mike,
Cordless phones designed for the "wrong" market have been a problem here as well. I'm not sure if 73.35 MHZ is authorized for cordless phones in NZ, but strong harmonics certainly shouldn't be radiated. According to my data, the 3rd harmonic of 73.35 falls right in NZ TV channel 10, for a start.
Here's a summary of the cordless p;hone frequencies authorized in the U.K:
http://www.radio.gov.uk/publication/ra_info/ra193.htm [This message has been edited by pauluk (edited 10-19-2003).]
