0 members (), 210 guests, and 28 robots.
Page 3 of 3 1 2 3
#137367 07/09/03 06:41 AM
pauluk Offline OP
Scott,
So when did the NEC first actually specify that an EGC must be green? (If not bare.)
How did the general use of colors say 40-50 years ago differ from today? Was the BOY system in use for 277/480 (was the 277/480Y even in use then, or were these systems just 480 delta?).
#137368 07/09/03 02:35 PM
paul — In the 1953 NEC Handbook the green/bare permission/use limitation is stated. Reidentification was permitted "by paint or other effective means."
Living in a rural area, I came across local 480Y/277V in plants that had medium-voltage service, and in sports-field lighting. The first significant recommendation I found in text is the classic 1955 Industrial Power Systems Handbook, by Donald Beeman.
In many older plants and commercial/institutionals, coloring is black-black-black(-white)+bare or metal raceway. Differing voltages having distinct phase identification varies, but I’ve found it in 1957-vintage institutional/research facilities.
#137369 07/09/03 04:04 PM
pauluk Offline OP
Thanks Scott.
So presumably where all phases were run in black they used tags or something similar for phase identification, where necessary?
I seem to recall a thread a while back discussing that in many areas red was used for the wild-leg on 4-wire deltas in the past, before the NEC requirement for it to be orange.
Page 3 of 3 1 2 3
