by gfretwell - 05/14/24 12:28 PM
Electricians revenge
1 members (Scott35), 215 guests, and 17 robots.
Diazed II fuse (2A)
[Linked Image from lazyseaman.com]
Screw cap
[Linked Image from elektro-moegelin.de]
Key ring to be screwed into the bottom of the fuse element (16A)
I wasn't able to find a picture of an entire element.
T-R...
Are these available in the 1-63A range? Found them in the US on Eurpoean-made machine tools.
C-H Offline OP
{Reposting info from an old thread}
Usually they are called DI, DII, DII or DIV. (Increasing in size and rating)
The ratings of the the different sizes, from small DI to big DIV, are as follows:
DI (maybe 1, 2), 4, 6, 10, 15/16
DII (2, 4), 6, 10, 16, 20, 25A
DIII (32), 35, (40), 50, 63A
DIV 80, 100A.
(Paranthesis indicates special order only)
The DII is the size corresponding to the ordinary E27 light bulb.
Types DII and DIII are very common.
[Linked Image from i.kth.se]
There are also similar looking Neozed fuses, which are a bit more modern and compact.
{Edited to make it more consistent and correct errors}
[This message has been edited by C-H (edited 04-09-2003).]
Texas Ranger, C-H,
Thanks a lot for the pictures.
I've seen these used over here once or twice, just can't remember where.
What sort of voltage rating do they have?. [Linked Image]
C-H Offline OP
250V for the smallest version and 500V for the larger versions.
That's an interesting point. On the North American continent, one version of 30-amp-and-under, 125-volt fuses come with "edison" screw bases identical to most incandescent lamps. They are generally obsolete—probably because about 85 years ago someone figured you could bypass a {blown} fuse with a {used-to-be-solid-copper} penny—a US/Canadian 1-cent coin.
[I first discovered diazed fuses used for control circuits in, of all places, a California 500-220kV utility switchyard.]
[This message has been edited by Bjarney (edited 04-09-2003).]
