What do modern-day British-market electric kettles use?
American coffee percolators, rice cookers and kettles use this funky "iron plug" which is two round pins for the inlet (and two round sleeves for the outlet at the end of the cordset) - probably a little closer together than a standard Europlug.
There's also one that's twice as wide. It all depends on the device - there are like three or four different varieties of these here. There's even one with a thermostat...for electric frying pans, I think.
Also, the appliance and cordset manufacturers here are wiseguys. They rivet the two halves of the bakelite shell together instead of using a screw and nut.
That way, if you have to replace the flex, you can't just reattach the plug to a new hank of bulk flex cut off a spool at the hardware store.
You have to buy a whole new cordset at many times the price!!! F&%$ing crooks!!!!
![[Linked Image]](https://www.electrical-contractor.net/ubb/mad.gif)
[This message has been edited by SvenNYC (edited 03-04-2003).]
