Seen the odd 2 and 4 Amp DII ones on control circuits.
They're _really_ rare by now, but once or twice I've seen 4A DII in domestic fuse boxes.
As a matter of fact, fuses 6A and below are _not_ stepped, i.e. they all have the same tip diameter!
Austria: we've got differen requirements for fuses/L characteristic breakers and B/C/D breakers.
1.5mm2: L/fuse: max. 12A, that's why we used to have 12A breakers. B/C/D breakers: max. 16A but depends on the installation method (insulated walls, for example drywall with rock wool call for derating). 2.5mm2: L 20A (though usually 16A max), B/C/D 25A (though rarely ever more than 20A, rather 16).
Neutral usually fused or switched on single phase circuits.
