679
8
Posts: 1,498 Likes: 1
Living in Scandinavia, one is never shocked by high prices. Most things are expensive or have a ten year waiting list... I once bought a €60 dimmer. It was just a plain white one of a common brand.
Why are prices so expensive there?
60 smackers for a DIMMER?????
Damn!!!
Here, dimmers cost around 5-20 dollars depending on the cost, quality, style and brand.
"Made in Sweden" makes things expensive. Like Volvos or Saabs. The only way companies can survive is by improving quality.
To help the prices up we have 25% VAT, 30% tax on company earnings and 50% income tax. Plus various other taxes.
>60 smackers for a DIMMER????? >Damn!!!
- Made in Sweden - Self-resetting breaker instead of fuse - Electronic over-current limiting - dimmers the load to rated current. - Adjustable minimum level of light - Can be used with electronic transformers - Push-button - remebers setting - Three-way switching - Quality feel - 600W instead of 300W (€30 for identical 300W version) - Box for surface mount
I happened to need a 600W surface mount dimmer and this was pretty much the only on the market.
[This message has been edited by C-H (edited 11-22-2002).]
Posts: 2,520 Likes: 2
What did you hook up to that dimmer? 600W is a lot of juice!
We used to have a dimmer in our living room, but the fuse always blew along with the light bulb. My father got so annoyed of always replacing fuses he decided that we din't exactly need the dimmer and replaced it with a standard rocker switch.
Another nice thing: homemade lamps. I guess that not many DIYers know the following: many light sockets accept 100W bulbs. However, the cord won't stand that long term. (or at least many cords). In said living room we shortened the lamp cord 10 cm every 2 years or so because we had a nice flash followed by darkness. After the 3rd or 4th time we replaced the cord (with an obviously better one) and from then on it worked. With 12V metal halide flush mount lights my dad switched to silicone insulated wires, because any other type of wire burnt down after some time.
I'm curious. Was this 100 watt bulb being used base up or base down? 100 watt bulbs throw out LOTS of heat and standard zip cord isn't designed to tolerate that kind of heat when you use a drop cord with a socket dangling from the ceiling. (note, I don't advocate dangling sockets on drop cords from the ceiling but I've seen rooms with such things) I've found maximum 60 watts is within safe limits for base up use and it doesn't deteriorate the socket or the cord. 75 is pushing it. If it was being used for a table lamp with base down, then maybe it's very bad quality lamp cord? Factory made lamps usually have a label that says something like "Warning, to avoid risk of fire use only maximum x-watt type-A bulb" (in the case of regular incandecent). First time I've ever heard of that happening. Scary ![[Linked Image]](https://www.electrical-contractor.net/ubb/frown.gif) [This message has been edited by SvenNYC (edited 11-22-2002).]
What's wrong with having the lampholder dangling from the cord? That's the way the're intended to be used, isn't it? (Provided that you tighten the strain relief properly etc.) I've seen a lampholder melted and burnt from a 100W bulb. Don't do it! Ordinary plastic lamholders are NOT intended for this use. Max 60W means max 60W. You can buy porcelain lampholders or use old metal holders if you want to use higher power bulbs. IMHO, bulbs 100W or more should have a different socket. European cords are designed to 70°C max operating temperature. Tex: I needed the 600W dimmer for a lamp with eight 40W bulbs and one 100W bulb and they don't make 420W dimmers ![[Linked Image]](https://www.electrical-contractor.net/ubb/wink.gif) [This message has been edited by C-H (edited 11-22-2002).]
Ok, I see. It was base down, and it wasn't zip cord, it was SVT, as it is always used here for lamps etc. Why not have that dangle down? There was a strain relief on the socket! It was a modern metal socket (they still sell them here, brass or iron) with porcelaine guts. The socket didn't fail, only the cord insulation. After some time the wires got contact and shorted. I've seen several plastic sockets fall into small pieces due to using 100W bulbs in them. And as I said, the faults stopped after we replaced the cord instead of just shortening it.
Those bigger Leviton switches, are (were)commonly used in suface mount wiring in barns. I have also seen the them in ivory, and P&S and GE brands. There is also a plethora of other fittings, namely 3-way switches, receptacles, and junction blocks.
Posts: 7,520 Likes: 1
I have some of the old-style British "tumbler" switches. I need to re-install by camera software (time-consuming task!) but I'll post some pics as soon as I can.
Classicsat, Welcome to ECN and the non-U.S. area. We have quite an assortment of people in here now from several countries.
