Electricians revenge
0 members (), 188 guests, and 17 robots.
#132554 01/27/07 10:36 PM
ITO Offline
How about a really good CHEAP pdf utility?
I just hate paying hundreds of dollars for Adobe.
101° Rx = + /_\
#132555 01/29/07 11:08 AM
For PDF I use Acroplot from Cadzation (www.cadzation.com). We have Acrobat Pro and Acroplot works much easier for what we do and converts to other formats. I have not used it for doing direct conversions though it can handle it (meaning you do not have to convert through AutoCad).
We use AutoCAD 2007. I like the product and the ability to customize it to how I work. I started out with version 9 coming from PCCAD (Printed Circuit Board CAD), Cadvance, and Generic CAD. The first two were far easier programs to use at the time, but I took and modified tremendously the AutoCAD to how I wanted it to operate and found that I preferred it.
What it still comes down to is AutoCAD is expensive and overpriced, but great if you have the time to get it to fit you. Yet if I ever want something for home use, I will definately look elsewhere.
#132556 01/29/07 07:07 PM
sabrown;
Can the Acroplot utility be used to make .PDF plot files?
Currently using a very old full version of Adobe Acrobat + Distiller (Version 4), for associated .PDF creations and such.
For .PDF Plot File saves (saved CAD files as .PDF Plot Files), I set the "Default Printer" to be the Distiller, then perform "Normal" Plot Jobs from AutoCAD.
Scott35
#132557 01/29/07 09:41 PM
ITO Offline
Kenbo
Ok installed and used ZWcad. It looks feels and functions just like AutoCAD, and the price is nice too.
101° Rx = + /_\
#132558 01/30/07 10:44 AM
Yes, Acroplot makes PDF - without Adobe or the PDF plotter within AutoCAD. It is nice because I can take a whole mess of files with multiple layouts and convert them to a single PDF file in one step along with a watermark saying "For Review Only" or anything else desired. Lot's of options and converts Office and image files. It is so good that I have had no desire to even look at AutoCAD Sheet Sets (which looks like a huge pain to me).
I have Adobe Pro 7.0 and Distiller on my computer also and never use it except when desirous to edit an existing PDF files.
#132559 01/30/07 12:35 PM
Two free 2D programs that may be worth investigating are Solid Edge 2D www.solidedge.com/free2D and Draft IT 2.01 www.cadlogic.com/products/draftit/index.htm.
Shane
#132560 01/31/07 12:12 AM
I use pdf955 http://site4.pdf995.com/download.html to create pdf files out of AutoCAD LT 2003 many times. It works like a printer driver. Point to it in the plot menu and name the file. It's free if you don't mind the short ad page or $10 if you want it clean. Great tool for anything. I send my quotes out with it too.
edit to add:
Of course the drawing is no longer to scale.
[This message has been edited by Jps1006 (edited 01-30-2007).]
