Electricians revenge
1 members (Scott35), 152 guests, and 14 robots.
#131656 05/31/05 06:38 AM
I bow to superior knowledge [Linked Image]. Yep, the bus being the source would make sense, it's more exposed. I think case design has some bearing as well as motherboard design though, especially with today's very high speeds. One of the nastiest causes of interference I have found is bad grounding. In fact, the level of TV interference from one of my PCs alerted me to the fact that the PSU input connector's ground pin had a bad solder joint [Linked Image]
Measuring 120v ac on the case of the PC was scary.
(I traced that to being half mains voltage of 240v from the relatively high leakage filter)
#131657 05/31/05 10:27 PM
Again, that is a filter to keep the switcher noise out of the power grid, not to protect the computer.
#131658 06/17/05 05:27 AM
Trumpy Offline OP
How do you work that out?
#131659 06/17/05 11:52 AM
Something they told me at IBM.
#131660 06/22/05 10:35 AM
Mike, you can always buy more expensive coolers on the electricity box-side or for the cpu, made of copper.
The world is full of beauty if the heart is full of love
