0 members (), 584 guests, and 19 robots.
I received a call to repair a circuit that was out. When I looked at the service this is what I found, what a mess.
- HCE727
May I ask how quickly you ran in the opposite direction?
---Ed---
F
Could you explain pic 4? Is that a slice through the cable, or a crack in the block showing the exposed cable?
Picture #4 is the original 60-amp service cable that was stuccoed over.
Hank
I worked on a service like the one in pic #2. Cept' the glass on the meter was broken and resting on a meter temp. Exposed live parts, the works!
Z
And the PoCo set those meters? I guess things are done differently around here - the PoCo guys would snicker as they drove away without getting within 10' of that thing.
What region is this in, if I may ask?
North East part of the country, Norristown, PA., right outside of Philly.
Hank
