0 members (), 164 guests, and 10 robots.
#123191 03/06/06 12:12 PM
**quote
The gray will just be the outer sheath though. It quite likely has red inner insulation
** end quote
D'oh - of course it will. All these colour changes are confusing!
**quote
practically all the overhead services here in which the two cables just drop down through the wall or roof void and terminate into the fuse and neutral block
** end quote
True enough for days gone by, but it is unlikely that any PoCo will install a service like that these days.
Any exposed service cable will be concentric to stop people tapping off the phase conductor, and anywhere where the phase conductor is exposed should have a security cover over the top.
Edited 'cos I can't work out how to put the quote things in using UBB!
[This message has been edited by ianh (edited 03-06-2006).]
#123192 03/06/06 06:55 PM
U
Ianh,
I took the covers off so you could see the set up, as you wanted a photo. Dont worry they were only on with a couple of wood screws & no seals.
As you can see from the photo the seals on the fuses are intact as is on the Meter.
The Grey supply Phase is an outer protective sheath on red insulation.
Paul got it spot on...(again)!
Don' forget this is about 30yrs. Old.
I originally went in this cupboard to get under the floor to help my workmate shift a radiator, now I'm sneaking photos of his dirty laundry!!!! LOL
All I Wanted Was A Cup Of Tea!!
#123193 03/07/06 06:34 AM
Click on the edit icon on this message to see how I quoted your text (the system won't let you actually change anything, but you'll get the edit box up and see the codes).
There's a summary of the UBB codes here:
https://www.electrical-contractor.net/ubb/ubbcode.html
[This message has been edited by pauluk (edited 03-07-2006).]
