ShoutChat Box
New tool
by gfretwell - 10/19/20 03:43 PM
Where is Everyone?
by Bill Addiss - 10/17/20 07:04 PM
Beyond Belief
by gfretwell - 09/27/20 12:03 AM
Questioning the electrical norms
by LongRunner - 09/23/20 06:38 AM
Smoke & mirrors?
by HotLine1 - 09/21/20 03:42 PM
Facebook follies, bad wiring
FPE in Germany pt.2
1 registered members (Scott35), 21 guests, and 13 spiders.
Voltage monitor/Data Logger #12297 08/06/02 07:45 PM
Joe Carpenter Offline OP
I need to find an instrument to monitor and record the output of a 24vdc power supply for a continuos period of 10 hours or more. I need something that will capture everything down to a voltage drop or spike with a duration as as little as a split second. Is there something available out there for a price of say $400 or less? I don't care if I need to link it to a computer to make it work.
Re: Voltage monitor/Data Logger #12298 08/06/02 09:37 PM
Bill Addiss Offline
Joe,
We've got 2 Datalogging Multimeters here in the store Both priced under $300
https://www.electrical-contractor.net/the_store/EX/ML710_720.htm
If you have any questions on this or other equipment feel free to call EXTECH @ (781) 890-7440 ext. 200 for technical questions.
Re: Voltage monitor/Data Logger #12299 08/07/02 08:19 AM
Does anyone have any experiance with these instruments? Will they detect something as minimal as a "flutter" in the voltage? Is it capable of capturing data this sensitive for several hours solid, preferably up to 10 hours?
Thanks
Re: Voltage monitor/Data Logger #12300 08/07/02 08:57 AM
Redsy Offline
Joe,
We use a Fluke 43B.
Very nice, but it costs around $2,000.00.
Re: Voltage monitor/Data Logger #12301 08/07/02 09:40 AM
Bill Addiss Offline
Joe,
The people over at EXTECH should be able to answer any questions you may have about this particular equipment and it's applications. That's a direct # to their tech dept.
Re: Voltage monitor/Data Logger #12302 08/07/02 09:48 AM
OK I'm placing an order for one today. I'll try and post the outcome on this forum.
Thanks everyone.
2020 National Electrical Code
Code (NEC)
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
MarkC10
MarkC10
CA, Inland Empire
Show All Member Profiles
BigB 3
270,710 Are you busy
204,950 Re: Forum
193,056 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
