565
35
I need to find an instrument to monitor and record the output of a 24vdc power supply for a continuos period of 10 hours or more. I need something that will capture everything down to a voltage drop or spike with a duration as as little as a split second. Is there something available out there for a price of say $400 or less? I don't care if I need to link it to a computer to make it work.
Posts: 4,116 Likes: 4
Joe, We've got 2 Datalogging Multimeters here in the store Both priced under $300 https://www.electrical-contractor.net/the_store/EX/ML710_720.htm If you have any questions on this or other equipment feel free to call EXTECH @ (781) 890-7440 ext. 200 for technical questions. Bill
Does anyone have any experiance with these instruments? Will they detect something as minimal as a "flutter" in the voltage? Is it capable of capturing data this sensitive for several hours solid, preferably up to 10 hours? Thanks
Joe, We use a Fluke 43B. Very nice, but it costs around $2,000.00.
Joe,
The people over at EXTECH should be able to answer any questions you may have about this particular equipment and it's applications. That's a direct # to their tech dept.
OK I'm placing an order for one today. I'll try and post the outcome on this forum. Thanks everyone.
