1,318
8
The key word is specced, not labeled, so if one does peel off the label from the battery, read the OEM model, and gets an equivalent replacement, that would likely suffice.
The whole thing is covered under a US law called the "Magnuson Moss Warranty Act", which in this case, the clause which prohibits tie-ins essentially prohibits warranty terms to require a particular source of replacemrnt components be used to maintain warranty.
[This message has been edited by classicsat (edited 01-23-2006).]
Notice the second caution on the units label.
Than look for the units rated output. Hmmm... Good point. O.K., so the unit comes supplied with 16W of lights, but that's still a very unhelpful label, and the way it's worded in conjunction with the Lithonia sticker on the battery certainly seems like more of a sales trick than anything else. Even the input rating is vague -- Is that 0.17A at 120V or at 277V? [This message has been edited by pauluk (edited 01-23-2006).]
Fellows, could it be that the battery, and only the battery has this sticker?
If you mess with a sealed battery, the battery would lose it's UL listing, not the housing, the charger, or the lights, just the battery...
Dnk....
I do not think there such a thing as a UL listed battery.
iwire wrote: I do not think there such a thing as a UL listed battery. Oh there is, but you have to use UL Classified Distilled Water. ![[Linked Image]](https://www.electrical-contractor.net/ubb/wink.gif)
Larry LeVoir Inspector City of Irvine, CA
Classicat,
I was interested in your mention of the 'Magnuson Moss Warranty Act'. At the FTC site I read that 'the Act does not apply to warranties on products sold for resale or for COMMERCIAL purposes'.
I was happy to see our government working for us but now I'm curious how warranties for commercial stuff is enforced. I'm guessing the lighting system is being used in a commercial environment. Do you know anything more about the legal portion?
I actually knowingly voided the warranty on some APC UPS that I used in an industrial application to power up a PLC control system. But at $500 a piece who really cares... when the system is handling $50 million a week in finished goods.
Oh yeah... and APC has the same deal on their batteries. They say 'use ours or else'....but they are just using the same ones that you can buy for half price from Battery Technologies. Anyone that's searched CDW for UPS batteries knows that the half price units are the same mfg.
If it looks like a duck, and quacks like a duck... it's the same battery. (for those that don't speak duck....if volts, Amps, Temp ratings, size, charge times and amp/hr etc....all match use the third party battery.) In the end use the third party you'll have something that's probably not been sitting on a shelf forever.
Light bulb companies make lights. Battery companies make batteries. The reason the light bulbs company's batteries cost more is because they have to buy them and resell/relabel them to/for us....
RSLater, RSmike
[This message has been edited by RSmike (edited 01-23-2006).]
It can matter. Batteries are called out by specific manufacturer and model number in safety listing reports. There are single-fault tests that are conducted in the charging circuit and in the load circuit. The battery must not become a fire/explosion hazard when subjected to these faults. A replacement battery may not have the same performance as the device in the listing report. Here is a good example of what might typically be driving this sort of product labeling - the following is from information technology standard IEC/ANSI/UL 60950:
4.3.8 Batteries NOTE 1 Requirements for markings or instructions are given in 1.7.15. Equipment containing batteries shall be designed to reduce the risk of fire, explosion and chemical leaks under normal conditions and after a single fault in the equipment (see 1.4.14), including a fault in circuitry within the equipment battery pack. For USER-replaceable batteries, the design shall reduce the likelihood of reverse polarity installation if this would create a hazard. Battery circuits shall be designed so that: – the output characteristics of a battery charging circuit are compatible with its rechargeable battery; and – for non-rechargeable batteries, discharging at a rate exceeding the battery manufacturer’s recommendations, and unintentional charging, are prevented; and – for rechargeable batteries, charging and discharging at a rate exceeding the battery manufacturer’s recommendations, and reversed charging, are prevented. NOTE 2 Reversed charging of a rechargeable battery occurs when the polarity of the charging circuit is reversed, aiding the discharge of the battery. Compliance is checked by inspection and by evaluation of the data provided by the equipment manufacturer and battery manufacturer for charging and discharging rates. When appropriate data is not available, compliance is checked by test. However, batteries that are inherently safe for the conditions given are not tested under those conditions. Consumer grade, non-rechargeable carbon-zinc or alkaline batteries are considered safe under short-circuiting conditions and therefore are not tested for discharge; nor are such batteries tested for leakage under storage conditions. A new non-rechargeable battery or fully charged rechargeable battery provided with, or recommended by the manufacturer for use with, the equipment shall be used for each of the following tests: – for evaluating the overcharging of a rechargeable battery, a battery is charged for a period of 7 h under each of the following conditions in turn: • with the battery charging circuit adjusted for its maximum charging rate (if such an adjustment exists); followed by • any single component failure that is likely to occur in the charging circuit and which would result in overcharging of the battery; and – for evaluating the unintentional charging of a non-rechargeable battery, a battery is charged for 7 h with any single component failure that is likely to occur and which would result in unintentional charging of the battery; and APRIL 1, 2003 CAN/CSA-C22.2 NO. 60950-1-03 ¨ UL 60950-1 156 P.1 – for evaluating the reversed charging of a rechargeable battery, a battery is charged for 7 h with any single component failure that is likely to occur and which would result in reversed charging of the battery; and – for evaluating an excessive discharging rate for any battery, a battery is subjected to rapid discharge by open-circuiting or short-circuiting any current-limiting or voltagelimiting components in the load circuit of the battery under test. NOTE 3 Some of the tests specified can be hazardous to the persons carrying them out; all appropriate measures to protect personnel against possible chemical or explosive hazards should be taken. These tests shall not result in any of the following: – chemical leaks caused by cracking, rupturing or bursting of the battery jacket, if such leakage could adversely affect required insulation; or – explosion of the battery, if such explosion could result in injury to a USER; or – emission of flame or expulsion of molten metal to the outside of the equipment ENCLOSURE. After completion of the tests, the equipment is subjected to the electric strength tests of 5.3.8.2.
I was installing an EBU many years ago, and had to move some components to use a (factory) KO.
The light developed some problems afterwards,and I called tech support to troubleshoot it. The rep told me I had "voided the UL listing" by using the KO, but he couldn't exactly explain why.
Well sice there's no such thing as a "warrenty" I don't think that replacing this battery with an equivelent would void the warranty ![[Linked Image]](https://www.electrical-contractor.net/ubb/tongue.gif)
But I'll warrant that Lithonia's attorneys might try to argue otherwise! ![[Linked Image]](https://www.electrical-contractor.net/ubb/wink.gif)
HCE727
Delaware County, PA, USA
