Electricians revenge
1 members (Scott35), 41 guests, and 9 robots.
#121316 07/05/05 05:08 PM
Trumpy Offline OP
Alan,
Note the hay crucifix at the ridge- this is to keep witches from putting bad spells on the building- and he was serious
Looks like they must have missed the crucifx out on that apartment block.
I reckon the witches must have put a spell on the wiring. [Linked Image]
#121317 01/19/06 07:29 AM
Je parle un petit peu de français.
I speak a little bit of french.
Merci Beaucoup
Many thanks.
Never to old to learn a few new words, especially when they are not in the dictionary.
Vive la France !
Cheers Ray
#121318 01/19/06 11:32 AM
Drywall already existed in the late 1950ies here too, but just didn't come into fashion until the late 1960ies or early 70ies. Don't kno about the GDR, maybe it didn't exist there at all. I have a strong dislike against that stuff since it's extremely easy to kick in. Until around 1880 Austria only knew rock, brick and logs as building materials, resulting in pretty solid construction. Around that time gypsum panels came up - 2 or 3" thick solid gypsum panels, 24x36" put up like brickwork, made of gypsum and scoria. Not as solid as brick but still quite substantial it was used until after WWII for non load bearing walls. Another drywall substitute is aerated concrete block.
For woodwork like finished attics for a long time Heraklith boards have been used, wood shavings pressed with cement. Since it's a full inch thick it's noticeably more substantial than drywall and due to the rough surface it can be plastered over with conventional plaster. Also to some extent thermal insulation.
The French and Italian style of just clipping a rats nest of cables to the facades has always amazed me. Compared to law-and-order Germany Austria has always been considered somewhat a balcan country, but no Austrian would do that even in his wildest dreams!
#121319 01/20/06 08:50 AM
Attaches-cables!? Va te faire foutre!
*(Clips!? We don't need no stinkin' clips!)
