1 members (Scott35), 169 guests, and 11 robots.
#120991 06/04/05 05:29 PM
Around here in NJ that kind of wiring was very normal. Most of the houses built and wired in the 50's-60's had a NM wire that had paper filler, and it had a derated #16 grounding wire. Some of the paper fillers even had a tar type of wrapping around them. It was also very common to ground the metal box out in the back of it using a bolt and a nut. The worst part about this job was that if you looked into the box when it was in a closed wall, you would loosen the screw (which you could see inside of the box). However you would be thinking that the screw went into a thread hole and not knowing that it was attached behind the box with a nut. Once the whole thing was loose, you were in trouble. You couldn't loosed it up anymore because the nut would spin behind the box and you couldn't tighten it back up because you couldn't get to the nut.
#120992 06/04/05 08:56 PM
The grounding method shown above is common in homes built in the 50's, only thing is the conductor is wrapped around a nail,(so much for good contact).The asphalt pipe is called "Orangeburg" works fine until tree roots find the joints, [Linked Image] (also was common in 1950's and 60's homes).
#120993 06/05/05 09:56 PM
]What sort of filler is that, in that piece of NM cable?.
It looks like it would burn pretty readily.
Yes, Trumpy. Here it is next to a piece of brand new 14-2 for comparison.
[This message has been edited by electure (edited 06-05-2005).]
#120994 06/05/05 11:11 PM
e57 Offline
Mmmmm... Comparision burning.
