0 members (), 953 guests, and 11 robots.
Page 3 of 3 1 2 3
#119530 12/31/04 12:59 AM
Question . Is the fire alarm finished or is this in the middle of a upgrade and will be installed properly when the job is near completeion.
#119531 12/31/04 10:58 AM
Contractor; Mam I can put that there it be a violation of the code.
Homeowner; This is my house and the code doesn't apply here. put it by the tub so it is convient for me.
#119532 12/31/04 02:01 PM
I am seeing this very often these days.
How, I wondered, could so many have placed the switches and receptacles over the tub?
Then I realised that the situation arose when the homeowner re-modeled, and replaced a standard tub with a wider, often "whirlpool" tub. The wider tub, and the space required for the pump, moved the edge of the tub out, under the switch/receptacle.
#119533 12/31/04 03:20 PM
"If that was a Sink, you'd hit your head on the light fitting when you washed your hands."
If that was a bathtub, you'd hit your head on the light fitting when you got in or out.
Page 3 of 3 1 2 3
