0 members (), 409 guests, and 40 robots.
#119495 12/30/04 06:15 PM
Welcome, Hi-Potter,
Yes that makes a very nice (a little expensive)installation, but you'd better put a switch in that W/P Extension Adapter.
Unless the wH came with the cord, I don't think that it can be connected this way.
All bathroom recps require GFCI protection, but no receptacles are required at all in this bathroom.
On another note: That water heater and the added plumbing under the sink sure make it ADA ngerous place for any one in a wheelchair. [Linked Image]
#119496 12/30/04 08:16 PM
Aren't water heaters normally mounted on the wall, high above the sink?
#119497 12/30/04 08:28 PM
"Yes that makes a very nice (a little expensive)installation, but you'd better put a switch in that W/P Extension Adapter"
In a public place, ( such as this looks like)...I don't see any other way to install this. I'd wire this just like it was a "insta-hot" unit, which are almost always located directly under the sinks.
GFI or no GFI...I would never cord and plug this installation. How do you tamper proof a corded unit?
In regards to the "switch"....I've always treated these types of units similar to restroom hand dryers. If you have to service those, you'd be tagging them out at the panel. ( since you can not install a switch)
But as usual, I could be wrong regarding all of this...
Regards
HP
#119498 12/31/04 01:34 AM
What do you think that waterheater will look like in a few years,with the soap and water being dripped on it?
#119499 01/08/05 09:32 AM
not a freindly place if you are drunk and have bad aim
#119500 01/08/05 09:45 AM
Electure,
I thought you must have made a typo there, but on closer scrutiny...... Ahaa!!. [Linked Image]
#119501 01/10/05 12:32 PM
These water heaters do in fact come with a cord attached. There was one installed at a former employer of mine and it came with the cord on it. While I don't know if it violates code at least it was plugged in to a GFCI outlet. Still kinda scared me though.
Ian
MarkC10
MarkC10
CA, Inland Empire
davey 1
554,300 Are you busy
428,605 Re: Forum
398,659 Need opinion
