185
17
Posts: 3,672 Likes: 4
Administrator Member
The road can be a rodeo Randy.
But in pic #2, is that a neutral bolted there?
Mark, Thats a piece of #18... wrapped around the set screw on the EMT connector in pic 3 & attached to the plugmold casing...
-Randy
Posts: 947 Likes: 4
In pic. # 4 it always irks me when Bozos wont set the boxes flush w/ the finished surface and then not doing anything about the floating receptacle,but at least the rockers did not use a router for the cutout.
Rollie, Im with you on that... It'd also save me $$$ so I wouldn't need the plastic sleeves also.. When I screwed the new GFCI in here, the box pulled forward & flush with the wall... makes you wonder how well the box is actually attached!
-Randy
