0 members (), 220 guests, and 22 robots.
#118222 08/14/04 09:32 PM
Got a call for a GFCI that wouldn't reset... Yanked the GFCI out & the neutral was BBQ'd beyond recognition... Also noted was the Plugmold wiring which I feel leaves something to be desired... (Like a raceway maybe!)...
On the way out, someone decided to make sure I was awake by attacking a concrete light standard with their Honda CRV & then a "crash-course" in swinging an instant 180° across a concrete median!... I'd call the results a draw...
-Randy
#118223 08/15/04 12:48 AM
e57 Offline
The road can be a rodeo Randy.
But in pic #2, is that a neutral bolted there?
#118224 08/15/04 01:36 AM
Mark,
Thats a piece of #18... wrapped around the set screw on the EMT connector in pic 3 & attached to the plugmold casing...
-Randy
#118225 08/15/04 02:07 AM
In pic. # 4 it always irks me when Bozos wont set the boxes flush w/ the finished surface and then not doing anything about the floating receptacle,but at least the rockers did not use a router for the cutout.
#118226 08/15/04 12:40 PM
Rollie,
Im with you on that... It'd also save me $$$ so I wouldn't need the plastic sleeves also.. When I screwed the new GFCI in here, the box pulled forward & flush with the wall... makes you wonder how well the box is actually attached!
-Randy
