1 members (Scott35), 167 guests, and 10 robots.
Page 3 of 3 1 2 3
#115797 02/13/04 12:42 PM
Jps1006,
I believe it's been discussed/argued several times here, but this is the only one I could find easily . . .
https://www.electrical-contractor.net/ubb/Forum1/HTML/000057.html
#115798 02/13/04 02:40 PM
Actually Sven, that is a real product. They're called Masque Wall Plates I think. Notice the warning at the bottom of the bag.... well I'm sure someone would try if that wasnt there. I dont trust them for soome reason, but I'm really not sure why... [Linked Image]
#115799 02/13/04 02:44 PM
Two thoughts from me. I remember and old inspector saying the ground should be the first to make and the last to break. If the ground prong is up the ground can disconnect before the hot and neutral. Thats why it goes down. Gravity being what it is. Second how many apliance today have grounds on them so the point of the ground protecting seem to be mute. Just my 2 cents.
#115800 02/13/04 05:12 PM
Sparked,
Seriously? My bad then... [Linked Image]
I don't like them either. My issue would be that the plug's pins wouldn't be going the entire way into the socket.
*EDITED TO REMOVE ASCII ART BECAUSE IT DOESN'T COME OUT WELL WHEN YOU USE VARIABLE WIDTH FONTS* (Sven)
[This message has been edited by SvenNYC (edited 02-14-2004).]
#115801 02/14/04 01:23 AM
Right the first time sparked! I only wish I had photoshopped the holes in. Some consumer (read sucker) will probably think these things are great and plug his space heater in one hole, and the outlet strip in the other. The shallow prong penetration is what bothered me too, and the thought of dust/debris building up between the cover and the receptacle is disturbing.
But as for the ground pin question...
[Linked Image from whisperscorner.com]
The real question is right or left? [Linked Image]
#115802 02/14/04 09:55 AM
LOL,
I saw this product at the ElectricWest show, and got a free t-shirt.
Their website isn't up yet, but it looks like they've got it under control!!
[Linked Image]...S
#115803 02/23/04 10:39 PM
My old apartment was ½ done with those Masque things... The maintenance crews were in the process of changing the prehistoric Slater backwires out to Decora's when the Home Depot a block from there imported what I can honestly say, isn't the greatest idea... I looked behind some of them & found the original recept with the prong holes nice & gray from overheating... But hey, they "look" good... (Till they melt) I'm kinda suprised to find a UL listing on those as well, since they do inhibit full insertion into a wall recept...
Page 3 of 3 1 2 3
