1 members (Scott35), 414 guests, and 29 robots.
#115675 12/03/03 05:26 PM
I think that I would think twice about hanging a red sticker on this
John,
Am I reading this right? [Linked Image]
#115676 12/03/03 08:34 PM
You know it might fall over with the weight of the red tag. A joke
Theres always enough room in the junction box.You just need a bigger hammer
#115677 12/03/03 10:18 PM
Bill:
Guess I should choose my words a little more carefully......
Like TheComputerWizKid said...it may fall over from the weight of the tag! I meant that if I was to "slap on the red tag" I probably would knock it over.
A definite RED TAG
#115678 12/04/03 05:49 PM
This is a 3R rated EXO, when installed properly, I've seen a few of them around but don't like them too much.
Here's a cut-sheet for George's "Invisidorf"!
Pretty neat stuff, huh?...S [Linked Image]
[This message has been edited by electure (edited 12-04-2003).]
#115679 12/05/03 04:42 AM
For the "After" picture of this install, look at the photo of another disconnect installed without support in the Violations section. It is about 1 swing of a ladder being moved from this to that.
#115680 12/06/03 05:00 PM
Within a year or two this disconnect will be the perfect beehive. I was on a roof this summer that is common to 10 dwelling units. The A/C units are on the roof and the disconnects are mounted the same way. I tried to open one and it was full of bees. The reason for trying to open it was the A/C unit was not working. I am allergic to bee stings, so I went home early that day [Linked Image]
Pierre
Pierre Belarge
#115681 12/06/03 05:11 PM
A definite RED TAG
I thought so!
#115682 12/06/03 05:42 PM
I used to use "Invisidorf" but it kept getting lost on the job. [Linked Image]
You guys are being a little picky aren't you?
This switch is braced with the piece of LFMC. [Linked Image] what more do you want.
Some duct tape over the holes? [Linked Image]
#115683 12/09/03 07:22 PM
I can hardly wait to see how this guy meets the requirement of a receptacle within 25 ft.
