Electricians revenge
0 members (), 205 guests, and 12 robots.
#114828 07/10/03 02:41 PM
webelect,
Please explain your cited violations. How can you know how the line and load is wired? Where in the NEC does it say that you can't have foreign power in an enclosure?
Don
#114829 07/10/03 04:18 PM
Sorry boss....I just got carried away praticing on those danged concentric bends
Donnie
#114830 07/10/03 07:25 PM
Other than gross overkill, why does it have to be removed? The 20a breaker is the OCPD. The 30a fuses should not be an issue, if they are, just replace them with 20a or even 15a.
Other than the close proximity what's the difference between this and a disconnect at the machine?
