0 members (), 88 guests, and 14 robots.
#114257 02/10/03 05:32 PM
Submitted by Gus M.
#114258 02/10/03 11:38 PM
Looks like a double BX connector used for Romex. I like the way the ground wire is brought back under the connector to make a "good" ground. It also looks like this was cut out of the system and replaced with a correct connector.
#114259 02/11/03 08:36 AM
Excellent!!
Reminds me of that magic trick with the swords and the "lovely assistant".
#114260 02/11/03 10:37 AM
It would be interesting to see what that center screw did to the insulation on those conductors inside... [Linked Image]
#114261 02/12/03 12:21 AM
Just noticed that it 3 conductor, not 2!! Hope he got the screw between the ground and neutral, even though it look to be between the ground and black!!!!
