183
Looks about normal to me, see this crap all the time.
This situation is certainly bad enough. I hate to think how much worse it will be if that water pipe with the corroded elbow ever lets go. Mike (mamills)
I,ve seen installations by licensed contractors that didn't look much better."But he was cheaper" It looks like crap and half of it doesn't work but it was cheap!
I really like the 220 circ that cuts across the bus, goes to tandem breaker on right side, and it looks a bit tight.
Do you see any grounds? The only ones I can make out are splitbolted together at the bottom of the panel (hovering over the panel buss).
SD It is best for a leader to be both feared and loved. But since this usually cannot be done, it is safer to be feared.
See it all the time.
I like the phone wire ground sneaking into the righ of the panel. It's the neatest wire in the entire panel.
