0 members (), 1,198 guests, and 12 robots.
#112680 08/26/01 10:51 AM
I thought we determined that WAGO's were comparable to back-plugging recepts and switches? Now they're OK???
I have had one failed WAGO in a recessed light. It was a service call after the bulb refused to come on when replaced.
Use wire nuts and tighten them until your wrist cracks.
Remember folks...
Loose wires cause fires...
(Well, loose terminals, but it doesn't rhyme as nicely!)
One of these days I'm gonna buy a Megger and test all these suckers myself... (I don't trust UL, I've seen to many weird things with a label...)
[This message has been edited by sparky66wv (edited 08-26-2001).]
-Virgil
5 Star Inspections
Member IAEI
#112681 08/26/01 12:59 PM
K
Sparky66wv
Sorry, I must have missed that discussion.
What do you think about the combination, wire nuts and solid conductors. Or if you mix solid conductors with wires consisting of several?
Fuseman
#112682 08/26/01 05:44 PM
It seems the trade is this way for wire nuts:
Orange: Rarely
Yellow: Sometimes
Red: Always
Grey: Never (see Red)
Blue: When you absolutely can't fit it in a Red.
This is sick, all they need to do is read the box.
Wagos
I Don't Trust 'Em
#112683 08/26/01 09:45 PM
electure has a point, even wire nuts can be bad if not used within their instruction, to emphasize again...
They must be connecting the size and number of wires that they are designed for, and they must be tightened much more than mere fingers can tighten... I use a wrench from Ideal (more like a large socket) that is used for the original Ideal Wire Nuts. Sans this wrench, use your lineman's pliers, get them tight.
(B-Caps seem really cheap to me...I've seen a few of those melt down too... When I say Wire Nuts, I mean the Ideal brand Wire Nuts...accept no substitute) Sorry I'll get off my soapbox now...
I hope I didn't offend you kent, it was Bill's response that threw me... (sorry Bill, you seemed a little too eager to give Wago's a try at the time... after rereading your post I see that you were just curious...my bad as the kids say!)
I could just be stuck in my ways... They'd have to be proven superior to Wire Nuts if I were to use them.
I do like the terminal screw idea however!
-Virgil
5 Star Inspections
Member IAEI
#112684 08/27/01 06:37 AM
Bill:
Just had a thought.
I have a catalog here from one of our suppliers which isn't too big and bulky, but has some fairly clear color photos of some of our common fittings and wiring accessories.
I'd be happy to send you a copy via snail-mail if you're want, then if you are able to scan it you can post anything that you think might be of interest.
#112685 08/27/01 12:38 PM
Kent, (& Virgil)
I don't think I would ever use the Wagos except in lightly loaded circumstances. They also seem very bulky. I have much more confidence in the wirenuts that we use for the majority of connections.
'66,
I don't know as I agree with 'Cranking them' though as I think the internal spring can get deformed somehow and possibly have some negative effects. (I agree they should be tight, but I'm not sure how tight you mean) Do the instructions have a torque recommendation? I always thought the tools that were made for this were to make it easier on the fingers and not so they could be tightened more. Anybody know?
Paul,
If you wouldn't mind sending it I'd be happy to pick out some interesting pictures. I'll send you my address.
#112686 08/28/01 01:07 PM
Originally posted by Bill Addiss:
Kent, (& Virgil)
'66,
Paul,
#112687 08/28/01 01:10 PM
Paul,
Thanks Bill. Package on its way to you.
