0 members (), 965 guests, and 9 robots.
#111637 01/11/07 12:53 AM
I think this might be a violation of 410.8(B)!
JohnJ0906
#111638 01/11/07 04:00 AM
Definitely within the storage space by the definition given in 410.8 (A). Whats with that soffit though? Is it solid? Did the electrician during rough-in forget to set a box in the correct location? I bet that cover's a bit tricky to get off.
Luke Clarke
Electrical Planner for TVA.
#111639 01/11/07 01:40 PM
I hope what really happened is the fixture was set correctly and there was a change in the closet shelving layout.
I have run into this quite a bit with older closet retrofitted with those wire organizers or a closet company comes in and does a closet organizer.
Unfortunately, what most electricians will see at first on a house plan will be a generic shelf and pole at about 6' high.
#111640 01/11/07 04:43 PM
Who said an electrician did this? [Linked Image] In addition to this, Dimmer on paddle fan, quad in bathroon has never worked, no gfcis on kichen counter, DW run from COLD water pipe, both sumps covered with carpet. Theres a handyman for you!
#111641 01/11/07 05:49 PM
Well, with the other problems you now mentioned, I'm suprised we weren't looking at a keyless lampholder instead.
#111642 01/12/07 10:22 AM
With the advent of LED lighting, as well as the sundry "closet organizers," I really think that it's time to consider the code allowing for suitably designed fixtures in close proximity to the clothes (or stored material)
I have seen at least two products that combines electricity and clothes rods. When we wire homes, we might want to consider placing a receptacle in the closet.
