0 members (), 723 guests, and 19 robots.
#111280 11/03/06 01:34 AM
Y
"If the meter dial rusts to a stop but the conductors keep conducting, is the electricity free?"
Meter parts are usually aluminum and various alloys, and the bearings are usually magnetic suspension nowadays, I think. It would be hard to envision one rusting to a stop, although you could adversely affect the accuracy. If any salt water got in there, corrosion would be the least of your problems.
#111281 11/03/06 10:35 AM
In areas around Galevston TX the primary (7200V)and secondary (120/240V)lines are buried but the transformer is mounted on a pole. No pad mounts are used. You see poles thru out the area with no wires between. This is to prevent damage durring tidal flooding.
