921
8
Hmm, wonder why the POCO bothered to install a new meter then... Around here they would pull the meter and put in a blank off plate and seal that... It does look like the building had a small fire eh? I wonder if its origin was electrical?? ![[Linked Image]](https://www.electrical-contractor.net/ubb/biggrin.gif)
Posts: 7,413 Likes: 10
OK, a POCO that don't cut the drop at the pole???
It looks like the old SEU was dropped (see top and left of meter pan, 2nd pic)
PSE&G does a disconnect (cut) at the pole, not at the drip loop/head.
Man, you've got good eyes, John! ![[Linked Image]](https://www.electrical-contractor.net/ubb/biggrin.gif) Mike (mamills)
Not only was the SEU cut (good call, HotLine1!) But I agree it looks as though there has been a fire.
Check out the corner of the roof eaves in the first and second pics.
Stupid should be painful.
Cut the drop at the pole, get everyone out and call the back hoe in.
Ian A.
Guys:
Thanks for the compliment!
I haven't seen a house with that type of siding in a really l o n g time. It used to be prevalent in Newark when I was a kid.
As to a "fire", possible but doubtful IMHO.
In my part of the world, the POCO will simply boot the meter and red tag (seal) it if a non-payment of service is involved. If it's a fire disconnect, a condemnation/code violation, or a theft of service, they will pull the meter (leaving the can open) and cut/tape the conductors at the pole. In a number of cases, they will go a step further, removing the entire drop from the pole to the weatherhead.
If the service is destroyed (as in the case of a serious fire), the POCO will recover whatever pieces of the meter they can find, and then remove the drop from the pole.
[This message has been edited by mamills (edited 09-05-2006).]
That 14 AWG is going to get awfully hot over the course of the next few weeks.
Cant even say yuck what a mess just what the Heck ( not the choice word i was going to use) were they thinking!!!!!!!!!!!!!!!!!
That cable looks a bit heavy to be #14. I'll bet it pre-color-coded-sheath #10. Maybe we can get Alan to go back and check.
Shinnston, WV USA
