0 members (), 723 guests, and 19 robots.
#111084 09/02/06 03:50 PM
Hmm, wonder why the POCO bothered to install a new meter then... Around here they would pull the meter and put in a blank off plate and seal that...
It does look like the building had a small fire eh? I wonder if its origin was electrical?? [Linked Image]
#111085 09/02/06 08:21 PM
OK, a POCO that don't cut the drop at the pole???
It looks like the old SEU was dropped (see top and left of meter pan, 2nd pic)
PSE&G does a disconnect (cut) at the pole, not at the drip loop/head.
#111086 09/02/06 10:23 PM
Man, you've got good eyes, John! [Linked Image]
#111087 09/03/06 12:36 AM
Not only was the SEU cut (good call, HotLine1!) But I agree it looks as though there has been a fire.
Check out the corner of the roof eaves in the first and second pics.
Stupid should be painful.
#111088 09/04/06 01:47 AM
Cut the drop at the pole, get everyone out and call the back hoe in.
Ian A.
#111089 09/04/06 09:09 PM
Guys:
Thanks for the compliment!
I haven't seen a house with that type of siding in a really l o n g time. It used to be prevalent in Newark when I was a kid.
As to a "fire", possible but doubtful IMHO.
#111090 09/05/06 10:16 AM
In my part of the world, the POCO will simply boot the meter and red tag (seal) it if a non-payment of service is involved. If it's a fire disconnect, a condemnation/code violation, or a theft of service, they will pull the meter (leaving the can open) and cut/tape the conductors at the pole. In a number of cases, they will go a step further, removing the entire drop from the pole to the weatherhead.
If the service is destroyed (as in the case of a serious fire), the POCO will recover whatever pieces of the meter they can find, and then remove the drop from the pole.
[This message has been edited by mamills (edited 09-05-2006).]
#111091 09/06/06 05:25 PM
That 14 AWG is going to get awfully hot over the course of the next few weeks.
#111092 09/06/06 08:54 PM
Cant even say yuck what a mess just what the Heck ( not the choice word i was going to use) were they thinking!!!!!!!!!!!!!!!!!
#111093 09/06/06 11:55 PM
That cable looks a bit heavy to be #14. I'll bet it pre-color-coded-sheath #10. Maybe we can get Alan to go back and check.
Larry Fine
Fine Electric Co.
fineelectricco.com
