0 members (), 435 guests, and 12 robots.
The open energized panel is an automatic OSHA citation if they would come onsite.
Don
Article 590 discusses temporary wiring.
Temporary wiring is exempt from many of the requirements for "regular" wiring. One need not use junction boxes for splices; we have an enormous amount of lattitude as to support, strain relief, and the like.
There are only two issues that I see. The panel cover is one; concievably, all these wires could simply pass through an unrpotected hole in the panel- or even between the cover and the case.
The other issue is the lack of GFI protection of these "temporary" circuits.
Pierre: No, I wasn't kidding. I simply contend that the degree of care required for such temporary arrangements depends on the circumstances, including duration of the work, accessibility to non-qualified persons, and occupancy during construction. What if the panel is in a locked room, to which only qualified personnel have access? Would you still object?
These are probably not so guarded, and so I'll grant you that the missing covers are probably a real violation, as Reno pointed out. But if the temporary receptacles are integral GFCI types, then there might not even be any other violations here.
In your hypothetical case of an occupied dwelling, I think I made it clear that a much higher degree of support and physical protection is required.
Your response is pretty typical for contractors who have not learned the proper way to install electrical installations, whether temporary or permanent.
Golly, that's a little harsh. Didn't I just say that how important it is that the final product meets code? You have no idea how many hours I've spent making my own installations "over-the-top" neat and workmanlike. Even the temporary ones.
[This message has been edited by John Crighton (edited 11-29-2005).]
590.2 All Wiring Installations.
(A) Other Articles. except as specifically modified in this article, ALL other requirements of this Code for permanent wiring shall apply to temporary wiring installations.
590.4 General
(A) Services.
Services shall be installed in conformance with Article 230.
Now if the pictures shown conform with Article 230 ... I am a monkey's uncle.
-Securing of cables to boxes, enclosures
-Fittings used
-Identification of circuits
-covers missing
-110.12, even if it is not admissable in court
...And we wonder why the "professional" perception of our industry has all but disappeared.
THATS RIGHT, THIS REALLY PEAVES ME!!!!!! FOR LACK OF BETTER WAYS TO SAY THIS IN A PUBLIC FORUM.
Pierre Belarge
