AE-Gifts, Affordable Everyday
0 members (), 451 guests, and 8 robots.
#107764 07/15/04 07:02 PM
Ground prong up/down,religion,and politics you can not win with those subjects.
I forgot one more, the Middle east.
#107765 07/25/04 01:55 PM
thx Bob i appreciate the advice maybe i will one day ... when i find out how.
ill be contacting ya on how i can do that
but yah these are nasty installs
and there were better areas for me to bring up the subject
[Linked Image] Tim
#107766 07/27/04 10:28 AM
Looking at that pic of the plug there also doesn't appear to be the usual hole at the end of the neutral blade. Could it be an Japanese cord set or something like that? I thought that all NEMA-approved fittings had the holes on 15 and 20A devices.
Hi Paul,
No, that's an after-market replacement plug.
GE-brand to be exact, made in China.
I call them "Walmart specials" because that's where they're commonly found. They're overpriced and the pins are flimsy and bend easily.
#107767 07/27/04 08:22 PM
Sven,
You sure that that's not the original molded plug that came on the pump, with the ground ripped out and half of the hot pin burned off? (the black one, not the yellow connector body)
#107768 07/27/04 11:16 PM
Scott,
I'll back up Sven on this, I have one of those square-ish GE plugs around here someplace from quite a while ago... (If I remember right, I bought it for a late night repair from a grocery store) The U-ground pin broke off pretty easily simply from trying to pull the plug out of a paint-caked outlet! [Linked Image]
Look where the person's thumb is, there's one of the screws holding the clamshell body together.
-Randy
