by Hutch - 05/13/24 04:23 PM
Electricians revenge
0 members (), 210 guests, and 9 robots.
#107382 10/09/04 07:40 AM
Okay, that makes sense. It does look like a welder, but I couldn't think of a way of getting 120V out of a welder.
#107383 10/09/04 07:42 AM
First lesson for becoming an "self learned electrician":
"The stuff already works without that third pin connectoed"...
#107384 10/09/04 09:43 PM
Ragnar,
The welder has an inbuilt generator in the unit that powers the Transformer to supply the Handpiece with current.
Personally, I'd lash a bit of PVC tape around that green flex to the rope beside it.
Can't have all that strain on them wires!. [Linked Image]
#107385 10/14/04 02:45 PM
The thing that's so sad about this is that extension cords are so cheap and so much easier to plug in than this mess.
You don't even need a pre-made extension cord.
You already have the cord. Cost of a realtively inexepensive heavy duty rubber grounded dead-front plug: $3.00 Mating socket $4.00.
Geeeez. I've actually seen people tap into 50-amp 250 volt receptacles in generators like that!!!
At one street fair a year ago I saw a cord stuck into a genny receptacle, with bamboo shish-kabob skewers to keep the wires from slipping out of the socket holes.
What's the going cost of a 50-Amp 250 volt plug these days? [Linked Image]
