0 members (), 479 guests, and 14 robots.
#106369 04/25/05 08:08 PM
This box was easily accessible- until the tenant re-modeled, and moved a wall. As you can see, there are still connections inside.
- renosteinke
#106370 04/25/05 09:35 PM
Is that reddish areas fire caulking? If so, I havent seen it used on horizontal penetrations.
#106371 04/26/05 05:52 AM
Maybe you could access through the missing KO
#106372 04/26/05 09:01 PM
Yes, the red stuff is fire caulk...this was a hallway, with double layers of sheetrock.
Of course, having a j-box in the middle of the wall raises all sorts of other issues....
As luck would have it, in the course of sorting out the wiring, this j-box was eventually completely abandoned.
