0 members (), 236 guests, and 10 robots.
Huh?? 60 amp service with metal strapping holding breaker in place on block of wood.
[Linked Image from nachi.org]
Courtesy: Raymond Wand Home Inspection Service www.nachi.org
AHHH!!! When will the plumbers ever stop messing with our wiring?
Take a look at the grounding/neutral? Is this a service panel?
Pierre
Pierre Belarge
That's outright criminal...
Might this little getup be a "retro-fit" where the breaker replaced a pony-cleat socket that was being used as a fuse holder? [Linked Image] [Linked Image]
[This message has been edited by SvenNYC (edited 03-22-2004).]
Thank goodness I'm not an inspector, because if I stumbled across this mess, I'd be so dumbfounded I wouldn't even know where to begin: "That's in violation of everything... just... just get rid of it."
-John
[This message has been edited by BigJohn (edited 03-22-2004).]
The character who did this is probably related to the same person who began using Lincoln Fuse Protectors. ARGGGHHH!!!!!
No wire bias here- I'm standing on neutral ground.
This panelboard is Amazing ....
BIG JOHN,
as an inspector one of my favorite replies is"i can't find anything right!hire a licensed electrical contractor and have him call for re-inspection" [Linked Image]
I think Thomas Edison himself wouldve busted a gut on this one.
