If the motor frame is plastic than there is no reason to 'bond' the motor because plastic is not likely to be energized.
If the motor frame is made of metal, then it needs to be bonded to both hot & cold copper water pipes with a solid #8 green copper conductor.
Articles: 680.42 (Indoor Spas), & 680.43 (Outdoors)
