e57:
For the record, I also am not a puck light lover.
Haven't seen the LED you mentioned around here yet.We started seeing them in signs about 1 to 1-1/2 years ago, replacing neon/fluorescent channels.
Sounds like a great idea, but like you say $$$$. Gys around here have been doing fluorescent with covers, usually mounted over the door to avoid the "great closet light debates".
BTW, if it has a rod (or facility) to hang clothing, it's a closet. (From the Building Inspector)
The wiring for the sign modules was a heated debate with the 'sign guys' as the EC's usually stop at the 120 volt feeder.
I saw the rod thing in a mag a while ago.
